1996 Ford F-150 engine shuts down at highway speed
EDDY2000
  • 1996 FORD F-150
  • V8
  • 100,435 MILES
96 f-150 302 auto 100000+mi. Problem is- at 55 or more mph. Truck will sometimes quit running that is I watch the tach go to zero ck engine lt comes on, i`m coasting. One or two seconds later engine starts back up by itself, down the road I go. Vehicle has many new parts-pcm, ign mod, ign coil, plugs, cap, rotor. The last time it set a code P0320 ign\dist engine speed input circuit malfunction. It was at ford garage 4 days didn't do it for them. Anyone have any ideas?
Saturday, September 12th, 2009 AT 10:00 PM
  • 109,885 POSTS
Have you checked fuel pump pressure?
Wednesday, September 16th, 2009 AT 7:57 AM
EDDY2000
  • 9 POSTS
Truck is currently back at ford garage. When it was there one other time they said it cked out ok. They called me, said two codes cam up, P0320 ign/dist circuit malfunction[is there a crank or cam sensor?] And they said something about checking fuel pump circuit. Thank you for your reply.
Thursday, September 17th, 2009 AT 3:40 PM
  • 109,885 POSTS
Let me know what you find out.
Thursday, September 17th, 2009 AT 8:01 PM
EDDY2000
  • 9 POSTS
Roger that
Friday, September 18th, 2009 AT 9:04 AM
EDDY2000
  • 9 POSTS
Back from Ford garage in sept 16 out sept 25 replaced crank sensor/ign. Stator they told me it`s odd that this vehicle has both, that maybe this happened during the middle of the model year?All I know is it puzzled the hell out of me. She seems to be running ok but i`ve only had her back a few days, sure hope that it`s cured. Thank you for your interest. Please keep this info in memory bank may need it sometime.
Sunday, September 27th, 2009 AT 9:34 PM
  • 109,885 POSTS
Let me know if the problem comes back.
Monday, September 28th, 2009 AT 7:18 AM
