1996 Ford F150 emissions code po446
86,000 MILES • 6 CYL • 2WD • MANUAL
RANDALL GOBEL
  • 5 POSTS
truck runs great 95% of time. occassionally on start up at normal operating temp, will run rough for about 10 seconds then smooth out and run great. Also seems to be a little hard on gas. Have tried changing various parts, @ vcv, canister purge valve solenoid, checked for vacuum leaks and somewhat inspected vapor canister without removing it. Any ideas?
Jun 3, 2010 at 9:30 PM
  • 75,988 POSTS
Clean out the idle air control valve and see what happens-also clean the mass airflow sensor with an approved cleaner
Jun 4, 2010 at 12:00 AM
