1996 Ford F150 DTC P0443
156,000 MILES • V8 • 4WD • AUTOMATIC
FALCONCAR
Evap emissions DTC P0443 is present. How do I fix it?
Thanks Rod
Jan 27, 2010 at 6:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
thanks for donating! many, many things can cause this trouble code to appear. follow the steps below to troubleshoot the issue. i only posted the first few steps because as i said, many things need tested here. let me know if the steps lead you to a further step not posted yet..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1513.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_451.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_166.jpg
Jan 27, 2010 at 6:37 AM
FALCONCAR
Thanks for the rapid response. I've got to figure out some of the acronyms, find where this stuff is located and perform the listed steps in the procedure. I'll let you know how it goes and if I need additional information.
One additional comment: Making hard copy of your response results is extremely small print. I enlarged the print, but it's not crisp and clear. Any suggestions?
Jan 27, 2010 at 8:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sorry not much of a computer tech person...did you try to just highlight my response and then click right button and choose print? then select print selected area only..?
Jan 27, 2010 at 2:09 PM
