1996 Ford F150 clutch linkage
BLAIN
Transmission problem
1996 Ford F150 6 cyl Two Wheel Drive Manual 100k miles
Good morning
I replaced my linkage and some oil (2-3 ounces) drained out from the opening. After comlpeting reassembly The clutch peddel would not return to its outward position(would stay downward toward floor) Do I put oil back in ? what kind? And how? Is this the reason for the clutch staying down?
Blain wright 17 years old in alabama
Jan 30, 2008 at 12:21 AM
98RANGERXLT
  • 301 POSTS
Yes you need to put oil in it just regular dot 3 brake fluid in it and bleed the system just unscrew the cap and pour some in
Jan 30, 2008 at 11:43 AM
