1996 Ford F150 check engine ligt
187,000 MILES • 6 CYL • 4WD • MANUAL
MEXICAN316
how do i replace the check engine light
Apr 21, 2009 at 10:13 PM
DAVE H
  • 13,383 POSTS
INSTRUMENT CLUSTER Removal & Installation Disconnect negative battery cable. Unsnap and remove instrument cluster opening finish panels. On A/T models, remove loop on shift indicator cable from ball stud on shift lever. Remove thumbwheel bracket screw. Detach bracket from steering column. Remove cluster finish panel. Remove 4 cluster screws. see Fig. 9 . Pull cluster away from panel, bottom first. Unplug connectors and remove instrument cluster. To install, reverse removal procedure. NOTE:Instrument cluster must be serviced as a complete assembly if speedometer/odometer assembly, instrument cluster printed circuit, instrument cluster gauge clips or instrument cluster backplate are malfunctioning.
https://images.2carpros.com/forum/automotive_pictures/266999_cel_1.jpg
Apr 21, 2009 at 10:26 PM
