1996 Ford F150 Airbag Code 12
1996 FORD F-150
111,500 MILES • 6 CYL • 4WD • MANUAL
TWENDY
My truck displays a airbag code of 12. The definition is low voltage. This occured immeadiately after I reset the codes when I replaced the crankshaft sensing unit. What can I do to fix this code or can I just reset it?
Jun 14, 2010 at 11:47 PM
  • 31,937 POSTS
Hi there,
I would go get a OBD11 scan done to confirm that this is a clock spring failure in the air bag, if so this should be done by a dealer or a mechanic with SRS experience.
mark (mhpautos)
Jun 15, 2010 at 12:26 AM
