1996 Ford F-150
BEW102
  • 1996 FORD F-150
Electrical problem
1996 Ford F150
I keep blowing the fuse for my brake lights and rear turn signals. Every time I try to put another in it just blows. What could be causing this?
Monday, September 6th, 2010 AT 9:28 AM
  • 110,055 POSTS
Do you have to use the brakes or signals for it to blow or does it as soon as you put it in?
Monday, September 6th, 2010 AT 8:13 PM
MATTHEW.ADELMAN
  • 6 POSTS
Blown fuses usually indicates there is an unwanted ground causing there to be a short in the system. Check your wires going to and from your brake lights and make sure no insulation is rubbed through causing the bare wire to short on the body or chassis. Hope this helps!
Saturday, September 11th, 2010 AT 3:21 PM
  • 110,055 POSTS
Yes, a short is caused by a power supply shorting to a ground. However, I was wondering if the fuse blew before the brakes or lights were used to determine if the short is before or after the switchs. Let me know so I can better direct you where to check.
Monday, September 13th, 2010 AT 7:29 AM
