Brake lights and rear turn signals
2003 FORD F-150
17,889 MILES
SPEIGHTS45
My brake lights and rear turn signals do not light up or work. My tail lights work but when I get on the brakes they don't get brighter. The top light on the cab works normal but the rest of it doesn't. We've checked and changed the fuses but nothing happened.
May 29, 2013 at 1:29 PM
SPEIGHTS45
I know it says 17889 Miles. It's supposed to say 178,889.
May 29, 2013 at 1:31 PM
HMAC300
  • 48,601 POSTS
check yoru grounds attailights for corrosion etc. then check to see if power is going through t/s switch it may be bad.
May 30, 2013 at 12:01 AM
