I hear a loud "thunk" when I shift into reverse. Could this be a result of a clogged filter or something worse
Wednesday, September 29th, 2010 AT 5:07 PM
MECHANIC
Have you checked universal joints?
SPONSORED LINKS
Friday, October 1st, 2010 AT 11:52 AM
SLEE87
MEMBER
I have not and i'm not totally sure what I would be checking for
Friday, October 1st, 2010 AT 1:53 PM
MECHANIC
The u-joints are located at both ends of the drive shaft. On a flat surface, place the parking brake on, place the vehicle in neutral, and check for excessive up and down play in the u-joint.
