1995 Ford F150 very hard shifting periodiiodly
130,000 MILES • V8 • 4WD • AUTOMATIC
PBERNHOLTZ
changed fluid no signs of wear clean... e4od may be prolblem but it only happens spontaniouisly, hot or cold but noted that Overdrive lite flases on the shift stick when prolbem occurs ,cantell me what to do or if any body has this prolbelm. I feels like some one rear ended you about 20 mph. thank you. paul.
Jun 26, 2010 at 2:26 PM
  • 110,248 POSTS
It sounds like a shift solenoid problem. If the OD light is flashing, you need to have the computer scanned to identify where the problem is coming from.
Jul 2, 2010 at 3:08 PM
