Replaced lock cylinder, will start truck but not shut it off. What thing should I look for?
Sunday, May 30th, 2010 AT 10:50 AM
KHLOW2008
MECHANIC
Hi tamarak40a,
Thank you for the donation.
The key lock cylinder is not turning the ignition switch to the off position. Check if the ignition switch is seated correctly and the bit for turning the ignition switch is not worn off too badly.
