Truck wont turn off. Replace ignition switch?
CAHERMAN2000
  • 1995 FORD F-150
Truck wont turn off. Replace ignition switch. Turns on fine. Still wont turn off any ideas. This is the first time it ever done this.
Tuesday, August 10th, 2010 AT 5:56 PM
  • 109,885 POSTS
Are you sure the ignition switch is properly adjusted? When you turn it to the off position, it should cut the power to the PCM (ignition, fuel.)
Tuesday, August 10th, 2010 AT 10:13 PM
CAHERMAN2000
Yes it even turn properly and makes a click noise very quietly. When it is put in to the turn off position, but noting happens. Because the problem is not the switch it is the ground wire that runs to the switch. Dose anybody know were to find the wire end that connects the ground to the switch?
Wednesday, August 11th, 2010 AT 12:08 AM
CAHERMAN2000
To to shop it has to do with the gear in the column thank by the way it a $300 job just in case someone else has this promblem.
Wednesday, August 11th, 2010 AT 3:39 PM
  • 109,885 POSTS
What gear are they refering to?
Wednesday, August 11th, 2010 AT 10:44 PM
