1995 Ford F150 truck wont move
147,000 MILES • V8 • 4WD • AUTOMATIC
SHANECAINES
I drove my truck to the mechanics garage and needed my transmission pan gasket replaced so he said do the filter as well so I did and they said now the truck wont move and that I need a new pump or tranny I know for a fact they did something wrong because i drove it there that day and have never had a problem. They said they double checked the fluids and they were fine and the filter is definitly the right one they say so what could the problem possibly be so I can get my truck back
Feb 6, 2010 at 10:58 PM
2CARPRO JACK
  • 11,533 POSTS
If they left the o'ring off the filter it may be sucking air into the pump, causing it to not work.I would definitly tow it to a trans shop and have it looked at, that is alot of coincidence.
Mar 24, 2021 at 5:01 AM
SHANECAINES
they said they double checked the o ring as well could it be the pump isnt priming back up and to try and over fill it to try and get it to prime
2CARPRO JACK
  • 11,533 POSTS
I have never seen a trans pump "lose its prime" doesnt mean it cant happen I guess, but I havent seen t in 20+ years. There are electrical connectors on the solenoids in the trans valve body, maybe they accidenatlly hit one and caused it to lose connection
