1995 Ford F150 transmission leaks
KEVINRAYROBINSON
Transmission problem
1995 Ford F150 V8 Four Wheel Drive Automatic
just put a new gasket on, transmissions been leaking since i got it, so i put a new gasket on, it stills leaks above the bolts on the pan.
what should i do?
Jun 14, 2010 at 3:36 AM
  • 110,248 POSTS
What type of gasket did you use? Was it cork? How tight did you make the bolts? Also, did you peen the bolt holes back before replacing the pan?
Jun 16, 2010 at 3:52 PM
