1995 Ford F-150 Transmission leaking, HELP!
BIGBLUE95
  • 1995 FORD F-150
  • V8
  • 4WD
  • 87,116 MILES
Ok, so I just bought a 1995 ford f150 long bed, 87k miles. Runs, drives, looks good. Now for my question, a couple days after I bought it I noticed that it had a puddle under it. So I checked the puddle and it was tranny fluid. Ive noticed the truck shifts a little firm into second gear, but smooth through all the rest. So I got underneath it and it seems to be coming from the back of the pan, and checked the dipstick, and it was overfilled. Any ideas onb whats wrong with her? Is it just a bad pan gasket or something more serious? I'd APPRECIATE any help you could give me.
Sunday, March 30th, 2008 AT 6:38 PM
MASTERTECHTIM
  • 4,750 POSTS
If its overfilled then either the guy is trying to hide a leak on you or he overfilled it. Overfilling the transmission will cause fluid to come out of the vent. You should start by changing fluid, filter and gasket, clean area and then run truck and look for leaks. That would be my course of action.
Wednesday, March 24th, 2021 AT 1:19 PM
