Monday, April 21st, 2008 AT 3:05 PM
MY FORD F-150 5.0 QUESTION IS THIS. MY OIL PRESSURE WILL BE IN THE NORMAL RANGE FOR A FEW MILES THEN ALL THE SUDDEN IT DROPS TO ZERO. THEN IT COMES BACK TO NORMAL PRESSURE. WHEN IT DROPS TO ZERO AFTER A SHORT TIME IT WILL START TO TICK, THEN THE PRESSURE MAY RETURN TO NORMAL. I WAS THINKING OIL PUMP OR BEARINGS UNLESS YOU CAN PUT ME IN A DIFFRENT DIRECTION. THANK YOU.
