1995 Ford F150 Noise while clutch engaged
1995 FORD F-150
172,000 MILES • 6 CYL • 2WD • MANUAL
JROD95F150
I have a 2wd ford f-150. There is a squeaking noise while the clutch is engaged and the throttle is pressed. It stops when I let off the gas. There is also a vibration that starts at about 35 mph. If I let off the gas or push the clutch in the vibration stops. Both the noise and vibration occur only when the clutch is engaged. If it were a bad U-joint wouldn't it vibrate and make noise whether the clutch is engaged or not? Is it more likely a transmission output shaft bearing/bushing?
Nov 16, 2008 at 2:26 PM
  • 31,937 POSTS
Hi there,
if this noise is constant with the clutch be pressed i feel it will be a faulty release bearing, try pussing in the clutch slowly and if the noise starts with the clutch pressure coming on, it will be the release bearing.
mark (mhpautos)
Nov 16, 2008 at 7:59 PM
