Catalytic converter red hot?
178,000 MILES • V8 • 2WD • AUTOMATIC
RANDYMCDW
hi my name randy i have a 1995 f150the truck ran great when i frist got it.but i wanted to put a tune up on it and i did also put a 02 sencer idle control air control plugs wires cap rotor,and now it has a miss to it. I tried driving it no power and when i look under the truck the catalac converter was beat red. could you please help i've spent a lot of money and it seen like the more new stuff i put on the worst it runs.
Thank you Randy from fl
Jul 25, 2008 at 3:26 PM
BMRFIXIT
  • 19,053 POSTS
its the firing order
u had installed the wires in the wrong firing order
what do u have for engine?
Jul 25, 2008 at 10:20 PM
RANDYMCDW
well i went on line and got the firing order but i have a 5.0 its funny because all i did was check the plug in the #5 cilder and i cracked the plug so i needed to change it. i did and then thought well maybe i did put the wires on wrong,so i moved them one up i think. After that it stared that miss.On the front of the truck theres the firing order i went by that,and also went on line.it seems like the #5 is dead theres fire but when you pull the wire nothing changes in the motor. i was told the vale was not closeing but that dosent make sence because all i did was change the plug didnt drive it at all and before that it ran fine. please help. Thank you Randy
https://images.2carpros.com/forum/automotive_pictures/218628_2055475279_s_1.png
Jul 27, 2008 at 5:27 AM
BMRFIXIT
  • 19,053 POSTS
remove and replace the spark plug on that cylinder
u may have a bad spark plug
i have seen a lot of them new out the box and no good
if u need the firing order let me know
what engine u have
Jul 27, 2008 at 7:50 AM
RANDYMCDW
yes i'd like the firing order for that i have a 5.0 v8
Jul 28, 2008 at 12:09 AM
BMRFIXIT
  • 19,053 POSTS
this is what i have good luck
https://images.2carpros.com/forum/automotive_pictures/99387_f150_firing_1.jpg
Jul 28, 2008 at 9:23 AM
