1995 Ford F150 leaking
1995 FORD F-150
204,000 MILES • 6 CYL • 2WD • MANUAL
DROFREHTUR
My steering box is leaking alot of power steering fluid.Am I in danger of the steering failing while I`m driving or will I just be going thru alot of power steering fluid.It appears to be leaking out of the bottom of the box.
Aug 24, 2009 at 7:31 AM
You'll be going thru a lot of fluid-Why don't you get underneath and try tightening it might stop leaking or change the gasket whatever-Being in danger you're vulnerable in different situation.
Aug 24, 2009 at 7:55 AM
