1995 Ford F150 LEAF SPRING
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
PLINK328
wHAT IS INVOLVED IN REPLACING LEAF SPRINGS IN MY TRUCK?
May 18, 2009 at 10:37 AM
RACEFAN966
  • 5,029 POSTS
Not to bad just alot of elbow grease. You will need to remove the rear driveline and then unplug the rear abs sensor and brake line to the rear end. Then unbolt the rear end via the ubolts and roll it out. Then remove the eye bolts at the frame and the shackle on both sides and replace in reverse order.
May 19, 2009 at 3:21 PM
