1995 Ford F150 ignition control module
135,000 MILES • V8 • 2WD • AUTOMATIC
SAULSGIVER
my problem is my truck starts when it wants to.I have replaced the fule pump and filter(twice) and the fuel pressure control mod. I am told the only thing left is the ignition control mod.when putting the truck on the computer it reads all ok. the truck will run fine for several days and then of a sudden it will not start. this last time I loaded it on a trailer and when I got home, it started!!!. Will someone tell me I'm on the right track with the ignition cont.mod. and also where to locate it
May 24, 2009 at 5:27 AM
JDL
  • 16,098 POSTS
Hello, did you do any testing before replacing anything? Are there any codes? You need to test when the problem occurs. When it refuses to start, is there spark at the plugs?
May 24, 2009 at 6:08 AM
DRCHASE
It is located at the base of your distributor. It is either a gray or black colored module
May 31, 2009 at 7:44 AM
