Hydraulic clutch adjustment
1995 FORD F-150
88,000 MILES • 6 CYL • 4WD • MANUAL
FRED SCHUTTE
How do you adjust the clutch on my truck?
Nov 20, 2009 at 3:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
There is no adjustment because the system is self adjusting. Here is what the book says
"No clutch linkage or pedal travel adjustments are required"
So if the clutch is bad which you can tell from this video
https://youtu.be/EpBMj5ZY_bo
if so here is how you replace a clutch in a similar car.
https://youtu.be/JpzefqEeVGE
Cheers
Mar 24, 2021 at 5:21 AM
