1995 Ford F-150 Hard on gas
  • 1995 FORD F-150
  • V8
  • 4WD
  • 270,000 MILES
I have a 1995 f150 5.0 engine, the engine starts perfect when its cold, but after it has sat for 10 mins or longer it is hard to start, it cranks for a good 10-15 seconds before it will fire, then it runs perfect, has lots of power, I can smell a hint of gas in the cab. Im thinking the TPS switch, but not a 100% sure. Once it cools off then its starts with out a issue. And its also, im thinking hard on gas, it will only get mabey 200-300 km to a tank which is roughly 100 to 150 miles.
Monday, June 7th, 2010 AT 8:34 PM
  • 109,901 POSTS
Has the check engine light ever come on? Also, I agree. That is really bad fuel mileage. The truck has at least a 19 gallon tank.
Let me know about the light.
Monday, June 7th, 2010 AT 10:25 PM
Yes the engine light does come on, and it stayes on, I had to put a bulb in, because the previous owner took the bulb out. If you need more info just let me know.
Duane
Wednesday, August 11th, 2010 AT 5:56 PM
  • 109,901 POSTS
Nioce guy to remove the bulb. What I need you to do is have the computer scanned. Most parts stores will do it for free. Have that done and let me know what trouble codes they find.
Wednesday, August 11th, 2010 AT 10:51 PM
