1995 Ford F150 fuel canister in engine compartment overflow
172,000 MILES • 6 CYL • 2WD • MANUAL
MCKEEVER1028
hi my 1995 Ford F-150 is leaking gas from a small canister down in the lower passenger side of the engine compartment. the canister has two spherical caps on it and two lines coming out of it. one line goes to the engine, while the other goes back towards the fuel tanks. the truck does have the dual fuel tanks but the front tank hasnt worked since i got the truck about a month ago. it is leaking so much fuel that the truck is only getting about 7 to 9 miles to the gallon. any help you could give me would be very much appreciated
Dec 27, 2007 at 12:59 AM
2CARPRO JACK
  • 11,533 POSTS
Front tank doesnt work? could be the rear tank pumping the front tank so full that the fuel is getting to the charcoal canister.I would start by repairing the front tank, and replacing the canister, should take care of the problem
Dec 27, 2007 at 11:58 PM
