1995 Ford F150 emergency flashers
120,000 MILES • 6 CYL • 4WD • MANUAL
EJHF150
I have a 1995 F150 with 120000 miles. I am having an issue with the emergency flashers. They are very dim, the turn signals work well. I have replaced the flasher fuse, do the emergency flashers have a separate ground or would it be the switch dropping the voltage? Also could you recommend a good shop manual?
Aug 9, 2010 at 5:43 PM
  • 110,248 POSTS
Did you replace the flasher or just check it? As far as the ground, they use the same one.
There are many good manuals. I'm not allowed to recommend any part names because people may think we are trying to sell certain products, and we're not. However, the one I use can be accessed from this web page. Check under the site menu.
Aug 10, 2010 at 3:26 PM
