1995 Ford F-150 Clutch Issues
DIEGO CLARK
  • 1995 FORD F-150
  • 6 CYL
  • MANUAL
  • 145,000 MILES
I am having a hard time trying to keep my vehicle running. I had it repaired about 3 weeks ago and the same problem kept coming up. The clutch does not activate and I am unable to start my vehicle. Brake fluid is slowly leaking from somewhere underneath my truck.
Sunday, July 25th, 2010 AT 11:46 AM
  • 109,885 POSTS
When this happens, do you have pressure on the clutch pedal? Also, Is the clutch fluid full? That may be the brake fluid you are seeing under the truck. It could be coming from a bad slave cylender to the clutch.
Monday, July 26th, 2010 AT 12:10 AM
DIEGO CLARK
The slave cylander fluid is full. I had the master cylander and the slave cylander replaced about 4 weeks ago. There is pressure on the clutch pedal and it just hits the floor and does not come back up like it is supposed to. I did notice a few changes after I received it back from the shop, i.E. Harder to shift than before.
Saturday, July 31st, 2010 AT 8:55 AM
  • 109,885 POSTS
It sounds like something isn't put together correctly or the pressure plate is bad. Have you contacted the shop?
Saturday, July 31st, 2010 AT 8:41 PM
