1995 Ford F150 clutch
87,986 MILES • 6 CYL • 4WD • MANUAL
WAATWELL
I had a clutch master cylinder go out so I replaced it. I bleed the system as required, had good pedal for a day. Next day, soft pedal to bottom , but clutch feels good. Do you think Ineed to re-bleed the system?
Aug 12, 2010 at 3:57 AM
  • 110,246 POSTS
I would try that, but it shouldn't need rebled. You may want to check the slave cylender to see if it is leaking.
Aug 12, 2010 at 3:29 PM
