1995 Ford F150 Clutch
150,000 MILES • 6 CYL • 2WD • MANUAL
KILOWATT
replace the clutch in the truck last week with new pressure plate, disc, throw out bearing, with the slave cylinder, and the clutch master cylinder the clutchis releaseing soon as it comes off the floor and is very had to shift after it gets warm
Feb 26, 2009 at 6:27 AM
BILLYMAC
  • 2,204 POSTS
hi you have air in the clutch system.fill the resavoir crack the bleeder just so you are getting drips .let sit for a few hours tighten bleeder fill resavoir pump clutch until pedal is right. very complicated clutch system here
Feb 27, 2009 at 9:57 AM
