Im not sure just looking for a opinion on this one .. I ve been told many things on this one .. the truck takes off fine drives fine .. but after the Tranny warms up you get a steady Knock knock knock type sound when you slow down under 15 ( note this only happens in Neutral or with the clutch pedal depressed. I ve been told everything from bad throw out bearing , to worn U-Joints .even the shop that put the clutch in has no idea what it could be ..
Jul 20, 2010 at 5:48 AM
