2004 Ford F-150 making a clicking noise at the front passeng
JOLVST
  • 2004 FORD F-150
  • V8
  • 4WD
  • 86,320 MILES
The clicking noise only start up when I start drivng and the faster I go the louder the noise get, but I can put it in 4WD the noise stop. CAN SOMEONE PLEASE HELP ME.
Friday, September 17th, 2010 AT 8:11 PM
MADMIKE1735
  • 951 POSTS
Not sure I understand. It clicks when you start the vehicle, or when you start driving? If you put it in 4x4 while driving and it stops, I would check your front driveshaft u-joints. Also check your front cv axles. Again, these are things that will cause a slight noise at low speed, and get louder with speed, and also disappear with 4x4 engaged. Let us know
Friday, September 17th, 2010 AT 8:18 PM
JOLVST
  • 6 POSTS
I will check the u joint&cv joint and i'll let u know how it goes. Madmike I thank you very much.
Friday, September 17th, 2010 AT 8:50 PM
MADMIKE1735
  • 951 POSTS
Your welcome, thats what were here for.
Friday, September 17th, 2010 AT 8:57 PM
JOLVST
  • 6 POSTS
It was the cv joint. I change the cv joint the noise stopped thank you very much madmike.
Tuesday, September 21st, 2010 AT 9:41 PM
MADMIKE1735
  • 951 POSTS
No problem. Glad everything worked out for you.
Wednesday, September 22nd, 2010 AT 9:43 AM
