1995 Ford F150 4 wheel drive
105,000 MILES • V8 • 4WD • AUTOMATIC
GENERAL12
it will not come out of 4 wheel drive.has switch on dashboard to select 4h-4l-2h.switch has been changed didnt help.thank you
Feb 18, 2010 at 6:19 PM
DR LOOT
  • 2,311 POSTS
Check your fuses inside the cab and under the hood make sure they are all good, then check wiring loom from the transfer case to the front end make sure the loom is not damaged to the front actuator.
Feb 19, 2010 at 3:20 AM
