1995 Ford F-150
EROCK1983
  • 1995 FORD F-150
  • V8
  • 4WD
  • 182,000 MILES
My truck loses oil pressure when it is at an idle. But only when its in gear. If its in park or neutral its fine. Even if its just a few RPMs above idle, the oil pressure jumps back into the normal range whether its in gear or not. What might be wrong
Saturday, July 10th, 2010 AT 3:55 PM
  • 109,885 POSTS
Are you hearing any knocking or ticking when it drops?
Saturday, July 10th, 2010 AT 7:09 PM
EROCK1983
No. No lifter clatter or anything.
Saturday, July 17th, 2010 AT 11:03 PM
  • 109,885 POSTS
Replace the oil sending switch. Chances are it is bad. It is easy to replace and not expensive.
Let me know if it takes care of the problem.
Sunday, July 18th, 2010 AT 1:41 AM
EROCK1983
Thanks, I will give it a try
Sunday, July 18th, 2010 AT 3:45 PM
  • 109,885 POSTS
Let me know if it fixes the problem.
Sunday, July 18th, 2010 AT 10:19 PM
