1995 Ford F-150 Diagonostics Codes
MKEELA
Computer problem
1995 Ford F-150 V8 Four Wheel Drive Automatic
I've done a diagonostics code check on the engine the code that comes up is 21 and when I looked up the code number to find out what it is it says ECT out of Self-Test range MAP/BARO out of Self-Test range. I'm not sure what this means. I was wondering if you could tell me what this means and what exactly it is that I need to fix or replace on the engine.
Nov 5, 2010 at 7:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
basically indicating a faulty engine coolant temperature (ECT) sensor. has the temp. gauge been inaccurate or showing overheating?
Nov 5, 2010 at 1:31 PM
MKEELA
thanks for respones now i need to no what code 12 is something to do with engine idel speed computer really doesnt say what it is
Dec 21, 2010 at 9:51 AM
