wiper motor replacement
220,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBINHOO1964
How do I access the wiper motor linkage to unhook old motor and install new motor?
Jun 14, 2010 at 5:55 AM
SATURNTECH9
  • 30,869 POSTS
Here are the instructions on how to change the wiper motor out.
REMOVAL AND INSTALLATION
1. Disconnect battery ground cable.
2. Remove both wiper arms, blade assemblies and upper antenna assembly.
3. Remove cowl grille attaching screws and raise the grille slightly.
4. Disconnect washer nozzle hose, then remove cowl grille assembly.
5. Remove wiper linkage clip from motor output arm.
6. Disconnect wiper motor electrical connector.
7. Remove wiper motor attaching screws and the wiper motor.
8. Reverse procedure to install.
Apr 3, 2021 at 12:01 PM
