clock spring
1994 FORD F-150
223,000 MILES • V8 • 2WD • AUTOMATIC
ENSEDA
I lost my horn and cruise control and the airbag light is now blinking.
1. Checking all fuses -okay.
2 Tested the relay - okay. (horn) only
Remove the steering wheel to check on open ground. Found a device with ribbon that was broke. This device looks to work with the turning of the wheel instead of the old slip ring for horn. Can the ribbon be repaired or does the unit have to be place?
Nov 8, 2009 at 4:41 AM
JDL
  • 16,098 POSTS
Yes, the clock springs go out all the time. Here is a guide to help you get it replaced:
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Cheers
Nov 8, 2009 at 4:59 AM
