1994 Ford F150 tachometer
170,000 MILES • 6 CYL • 2WD • MANUAL
JUSTWILLY23
I hooked up a tach in my ford to the negitive side of the coil, and it still wont read rpms. the engine is a 4.9 fuel injected 300cid and the ignition system in it is standard TFI-IV system. where do I tie in my wire to get it to read rpms?
Dec 21, 2008 at 12:43 PM
BLACKOP555
  • 10,386 POSTS
would be on the negative side, are you sure you have it hooked up properly?
Dec 24, 2008 at 3:13 AM
