1994 Ford F150 runs rich black smoke out the pipe
1994 FORD F-150
83,000 MILES • V8 • 4WD • AUTOMATIC
1954ALAN
All of a sudden when I started the truck it ran rough and smoked indicating a rich fuel condition. I drove the truck about 25 miles and the disconnected the battery,checked the intake and air filter wich was all good and then reconnected the battery and the truck ran normal. Drove the truck the next day and all was fine. Drove the truck later in the afternoon and the problem was back.
Aug 4, 2010 at 4:22 PM
  • 110,194 POSTS
Have you checked fuel pump pressure? You may have a bad regulator causing the pressure to get too high? also, has the check engine light come on?
Aug 4, 2010 at 6:11 PM
1954ALAN
Pulled the vacum hose off the regulator engine running and fuel was coming out of the regulator, installed a new regulator all is normal
Aug 4, 2010 at 6:23 PM
  • 110,194 POSTS
That will do it. I'm glad you got it fixed and let us know if you have questions in the future.
Thanks for using 2carpros.com,
Aug 4, 2010 at 8:00 PM
