1994 Ford F150 gas leak
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
LAPUUU
When I fill my gas tank, the gas leaks from neck leading to the tank. When I stop filling it stops leaking
Is there anything I can buy to stop the leaking?
I believe its rubber where its leaking. the hole is about a good quarter of a inch wide....
Thank You Much.... Bill L
Aug 11, 2009 at 12:58 AM
BLACKOP555
  • 10,386 POSTS
you can buy a new fuel filler neck/hose and put it on. make sure the clamps are tight when its put on. i wouldnt try fixing it. but if you wanted to you can use a piece of rubber and some seal all on it
Aug 11, 2009 at 2:40 AM
