1994 Ford F150 Fuel Pump Power Block Circuit Cold
1994 FORD F-150
RBLOME
Electrical problem
1994 Ford F150 V8 Two Wheel Drive 171000 miles
My F-150 runs a few days then won't start. I replaced the fuel pump which was original and whinning loudly. Ran for a few days and stopped. My mechanic then said no ground from the computer to the fuel pump so he put in a rebuilt computer.
Today it wouldn't start again. I tested the power districtuion box under the hood. At the fuel pump fuse there was no power to the fused circuit. The others around it all have 12 v. I tried all harness connections to see they were tight. Any ideas what I should do next? The power block has a nest of wires going into the back. Do you think it is the block, wiring harness or elsewhere?
Dec 2, 2007 at 11:28 AM
RBLOME
Lots of viewers to my issue but no suggestions. I have been thinking about it. If the issue is no power at this breaker slot...why not use a wire and just tap 12 volts from a neighboring non-crucial slot like the radio slot and feed the cold breaker slot for the fuel pump. I think I will try it. It is sure cheaper than a new wiring harness and power distribution box. It would certainly be a way to test if this makes the vehicle run.
Dec 4, 2007 at 11:48 AM
RBLOME
Jumping didn't work. I had it towed to a Ford garage. I'll post the solution.
Dec 5, 2007 at 1:25 PM
RBLOME
The Ford shop knew what to look for. The 94 F-150 was designed for two fuel tanks. I had just one. There is a wiring harness under the dash with a bypass of some sort plugged in if there is no switch for two tanks. The end of the plug had shorted and fused. Why it was intermittent I can't explain.
But this solved it. We were all looking under the hood and around the fuel tank for the problem when it was deep under the dash board. Now we know. I hope someone else with this issue finds this post.
Dec 18, 2007 at 12:07 PM
