Electrical problem
1994 Ford F150 V8 Two Wheel Drive 171000 miles
My F-150 runs a few days then won't start. I replaced the fuel pump which was original and whinning loudly. Ran for a few days and stopped. My mechanic then said no ground from the computer to the fuel pump so he put in a rebuilt computer.
Today it wouldn't start again. I tested the power districtuion box under the hood. At the fuel pump fuse there was no power to the fused circuit. The others around it all have 12 v. I tried all harness connections to see they were tight. Any ideas what I should do next? The power block has a nest of wires going into the back. Do you think it is the block, wiring harness or elsewhere?
Dec 2, 2007 at 11:28 AM
