1994 Ford F150 front suspension
16,400 MILES • V8 • 4WD • AUTOMATIC
WILDBILL25
What is the easiest yet proper way to change front coil springs ?
Feb 9, 2009 at 10:58 PM
BLACKOP555
  • 10,386 POSTS
jack up and support vehicle. next step is take off tire. from there disconnect the schock on one end so the axle can move. next lower axle till pressure is off spring and loosen upper retaining clip. then let axle down all the way. next remove the nut on the lower retainer nut and the spring shoudl come right out.
installation is opposite of reverse.
Feb 14, 2009 at 3:22 AM
