In order to replace the rear main seal you will have to remove the Starter, Drive Shaft, Transmission and the Flywheel plus the cross member supporting the tail of the tranny. So if you are up to the challenge and have the equipment to safely remove the tranny. Let me know and we will procceed. It is a task and can be a pain doing it on your own without the right equipment.
Most important piece of equipment is a tranny jack.
Nov 13, 2009 at 1:23 PM
