1994 Ford F150 Electric Transmission
J ONEMBO
Transmission problem
1994 Ford F150 Four Wheel Drive Automatic
Hi, I have the above truck and am having trouble with the electronic transmission. The odometer, which is digital went out and as a result the shifting from gear to busks. This happen once before, but when the odometer began to work the shifting was fine. I checked the fuses in the dash.17 & 18 and they look fine. Is there another fuse located somewhere or a part I must obtain to correct the problem?
May 5, 2009 at 10:23 PM
BMRFIXIT
  • 19,053 POSTS
Check on top of the rear end for a speed sensor with wires on it
if wires OK check Ohm sensor and or replace
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 5, 2009 at 11:06 PM
