1994 Ford F150 crank shaft pulley
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MR.KELLY
i have a haynes manual it says that if the engine is still in the truck you can put it in gear to keep the crank shaft from turning but when i try remove the bolt the shaft still turns? does anyone know what i should do
Jul 4, 2008 at 3:03 PM
BMRFIXIT
  • 19,053 POSTS
If you have a manual tranny that will work
but will not work if you have automatic tranny
use of an impack tool
and or try to hold the flywheel
Jul 4, 2008 at 11:33 PM
