1994 Ford F150 cracked engine block
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEITH ROSSI
towed uhaul trailer from fla then broke down in sc, tow guy say that the engine block is cracked. How can we tell if it cracked? I want to rebuild it but need to know how to do that.
Aug 10, 2009 at 1:32 AM
BLACKOP555
  • 10,386 POSTS
if the engine block is cracked you aint gona fix it unless you have a very good welder weld it and it still aint guarenteed.
to check if its cracked check the compression. and let me know. well have to performa few tests.
Aug 11, 2009 at 2:48 AM
