1994 Ford F150 coolant leak
179,000 MILES • 6 CYL • 2WD • MANUAL
LEONARDPERRY
cant find my coolant leak it leaks when it heats up . heavy drip ,dripping from where the trans meets the oil pan coming from some where . dont know
Mar 13, 2010 at 10:24 AM
  • 110,248 POSTS
Have you checked where the heater core hoses attach at the firewall? It could be running down over the trans. Also, it that isn't the problem, check the intake and make sure the coolant isn't coming from the top and running down. If it isn't from up top, the only thing I can think of is a freeze plug between the trans and the engine.
Let me know what you find.
Mar 14, 2010 at 3:33 PM
