1994 Ford F150 COIL SPRING
JULIE KOPP
Tires and Wheels problem
1994 Ford F150 Two Wheel Drive
FRONT COIL SPING MONT IS RUSTING THROUGH THE TOP.CAN THIS BE FIXED,IF SO HOW?
Apr 16, 2010 at 1:15 AM
BLACKOP555
  • 10,386 POSTS
it can be but your going to possibly have to get a new front end or check at autopart stores and see if you can get a new coil spring upper mount. if you can get one youll probably have to cut the old one out and mount the new one.
a junk yard might have a decent one to cut out but then youd have to have a good welder weld on the new one
Apr 19, 2010 at 3:41 AM
