1994 Ford F150 bad vibrations
133,567 MILES • V8 • 4WD • MANUAL
DENVERICH
1994 ford f150 4x4 5 speed manual transmission
the truck started to vibrate about a month ago I was driveing at highway speed it started to vibrate it when i was on the concrete portion of the highway it would stop vibrateing once I was on asphalt portions of the highway but now the truck vbrates all the time at speeds above 50MPHit feels as if the tires are out of balance
this what I have done: had the tires balanced, vibrations continue after it was balanced had the tires rotated and rebalanced the tire techs check for cupping or any other tire probleams and they found none had an alignment done. made sure that it was out of 4wheel replaced tires it still continue to vibrate ***NEW*** I jacked the truck of the ground strated the truck in two wheel drive checked the drive shaft, I put the truck into 4 wheel with speed of 20MPH, but the rear driver side wheel spun slower then the other three. Was able to stop and hold the tire with my bare hands and was able to spin the rear wheel, the opposite direction as the others where rotateing. Found .030 of inch of in and out of play
on the rear wheels.
May 21, 2008 at 4:13 PM
  • 31,937 POSTS
Hi there,
To start to narrow this down a bit, if the steering vibrates as well it will be a front wheel / steering problem & if the body shakes and the steering is relatively unaffected start looking at rear wheels & rear drive train. Start here.
Mark (mhpautos)
May 21, 2008 at 9:56 PM
RED_RUSSIAN1
  • 5 POSTS
Check or replace your u-joints. If the truck is lifted then U-joints will go out quicker than usual.
Jun 7, 2008 at 6:37 AM
