1994 Ford F150 94 f150 low voltage
140,000 MILES • V8 • 4WD • AUTOMATIC
DOCSLUDGE
My 94 f150 would not start so I replaced the battery, starter solenoid and the ignition switch. The truck will start if I jump it across the starter solenoid with a bump tester but it will not start with the key. It also shows low voltage on the in dash volt meter but after it starts it shows good voltage.
Nov 14, 2009 at 5:25 AM
  • 110,246 POSTS
When you turn the key, do you hear anything? Have you checked the starter relay, ignition switch? Also, make sure the ground to the engine block is good, clean and tight.
Let me know what you find.
Nov 16, 2009 at 2:39 PM
