1994 Ford F-150 no fuel pump nor spark
155,235 MILES • V8 • 4WD • MANUAL
JDURAN
i pulled in my drive way one morning and turned the truck off and ran inside to gather a few things. i tried to start the truck, it would not start. i have checked every thing. i have replaced the fuel pump and the pickup coil. there was nothing wrong with the original pump after i tested it. i even tested the new pump and it is ok. i have checked for spark also and no spark still. i checked all the relays and fuses and all are ok. where else do i need to check. does the ignition switch effect the spark and the fuel pump. also all the guages on the dash work. I've only had the truck for 2 years and has run great until that day. i have checked spark with a test light and a timing light. i have nomore ideas on what to do. i am not giving up!!
Sep 28, 2010 at 3:30 PM
  • 75,988 POSTS
Inspect and test the PCM power relay, If okay think computer
Sep 28, 2010 at 9:02 PM
